6pin hall sensor bafang bbhd controller
Julius Dades
10 µW
Does anyone on this forum know what is are the color references of the 6 pin hall sensor on the bbhd controller?:
1. Red - 5v
2. Black - ground
3. Grey ?
4. White ?
5. Blue ?
6. Purple?
My is guess is the grey, white, blue, purple are your yellow, blue, green is your typical hall sensor colours and one could them is the temperature cable. If someone on forum can match it correctly that would be greatly appreciated as I'm trying to make my own harness cable to connect the bbshd to different types of controller.
Thanks
JD
I would like to know this as well. Just joined for this reason.
After some trial and error, I manage to figure it out:
1. Red - Red (5v)
2. Black - Gnd
3. Grey - YELLOW hall sensor
4. White - BLUE hall sensor
5. Blue - GREEN hall
6. Purple - Temperature sensor
Give that a go. If your mid drive reverses and struggles to spin , play and swap it around between try different combos of the 3 hall sensors.
1. Red - Red (5v)
2. Black - Gnd
NO! Don't swap the hall sensor wires, swap the phase wires!
