dose0018@umn.edu
- Joined
- Jun 23, 2020
- Messages
- 37
Seeking a recommendation on finding a switch to switch between two battery packs on my Ebike build.
Must be able to handle the 36v and ideally a switch that does not have a "both" as I don't intend to run the batteries in parallel ever.
The two packs are identical 10p 4s packs with built in BMS but no on off switches.
Thanks
Here is one I was considering but was not sure if the specs worked?
https://electricscooterparts.com/powerswitches.html
Power Switch for eZip® and IZIP® RMB Electric Bicycles and Electric Bicycle Kits
On/Off/On dual battery selector power switch for Currie®, eZip® and IZIP® RMB (Rear Mounted Battery) electric bicycles and electric bicycle kits. Also used for the Forward/Neutral/Reverse switch on several small children's size electric ATVs and Quads. Six 1/4" wide terminals for push-on connectors on back side switch. Fits 30mm x 22mm rectangular mounting hole.
Wiring Directions
Item # SWT-154
Thanks
Wiring Directions
Item # SWT-154
