Hello all,
I am new to this forum and this is my first electric bicycle project. I've built many internal combustion trikes, racing karts, etc but this is my first electric project. I bought this Metro to use around town and have left it mostly stock up to this point. I'm on motor number three in the four years I had it and this one is starting to act a little flakey. So, I decided that a preemptive strike was in order, and proceded to look at a drive train replacement. I've been reading a lot of the info here and have looked into several alternatives, including middrive and lefthand drive.
I thought that I would document the project here and hope for some advise.
So here is the bike as it stands now.
https://www.dropbox.com/s/azk0o6uh79xa9oz/IMG_20130227_184830_3.jpg
I upgraded the brakes to avid bb7 from the stock five.
https://www.dropbox.com/s/rblv9sq9nls0prm/IMG_20130227_184918_1.jpg
also put on good high grip wide Crank Bros Pedals
https://www.dropbox.com/s/1tnsmys674zh89f/IMG_20130227_185004_3.jpg
I also replaced that toy shock that came with it with a lower end Rock Shox air shock. This made a world of difference with all that unsprung weight on the rear end.
https://www.dropbox.com/s/cq15a2382pqytth/IMG_20130227_185031_1.jpg
I added a topeak seatpost mounted rack and bags as the a2b was not standard. I also now have a protected area to put the controller, on the stock rack and below the topeak.
https://www.dropbox.com/s/7cu4vgvu7...m/s/teqq825rhd8ggnp/IMG_20130227_185128_1.jpg
I think that this is a great frame for the street fighter commute bike. The Steering geometry is good and the suspension works with the aftermarket shock.
The Battery storage and wire routing issues are all dealt with also. Plus I think it looks great.
Now as to the drivetrain, cheap junk.
So here are my goals with this project.
1. Reliability.
2. Moving the top end from the speed limited 20 mph to maybe 25, 30 tops.
3. Being able to deliver as much torque as possible in short bursts in the 15 mph and below range.
I basically want a street electric trails bike.
So I looked into two main drivetrain options.
1. Mid Drive
The mid drive option looked promising, I liked the ideal of a gearbox, but it was too complicated and expensive. I got a quote from ecospeed. too pricey. I looked at the GNG product but I don't have a machine shop.
2. Hubs
This turned out to be a better solution for me. This upgrade is simple and I can solve my power problems by throwing electrons at it like the electrical engineer that I am.
A hub based solution really leaves me just having to worry about breaking spokes and vaporizing copper. The thermal management can be done in the controller.
I'm not trying to build a fire breathing 8 Kw monster. I just want to have somewhere around 3 Kw around anytime I need it for short bursts.
From what I have read here I believe that's an achievable goal and can be done reliably. If I'm wrong please let me know.
So next the design decisions and what I chose as the replacement drivetrain
I wanted the cruise speed to be around 20 mph and still have a decent range.
So I went to http://www.ebikes.ca/simulator/ ebikes great simulator and chose the following:
HS3548 motor
ebikes 40a infineon controller
A 20" wheel
mountainbike aerodynamics and a 330 lb gross weight.
I set the battery to 72v 15 ah and a low enough internal resistance to make the controller the current limiter in the system.
When set at 42 % throttle on a 2% grade the numbers look like this at 18.7 mph
Mtr Torque 20.3N-m
Mtr Power 663W
Load 556W
Efficiency 78.6%
Electrical
Mtr Amps 29.4A
Batt Power 844W
Batt Amps 11.8A
Batt Volts 71.4V
Performance
Acceleration 0.281ft/s2
Consumption 45.1Wh/mi
Range 23 mi
Overheat In never
This means I can go up at 18.7 mph for 23mi on 15 ah @ 72v.
I'm going to try to stuff 30 ah in the frame and secondary battery so range is good and it shouldn't overheat.
looks like it will generate 95 lbs of thrust at takeoff and max out at 37 mph all on a 2% grade.
1. Reliability.
1. Mid Drive
2. Hubs
HS3548 motor
A 20" wheel
Mtr Torque 20.3N-m
Mtr Power 663W
Load 556W
Efficiency 78.6%
Electrical
Mtr Amps 29.4A
Batt Power 844W
Batt Amps 11.8A
Batt Volts 71.4V
Performance
Range 23 mi
Overheat In never
