MJSfoto1956 said:Still waiting on my controller to arrive...
madin88 said:Why do you wait for a controller to arrive was there a problem with the actual one?
Or do you try something different?
bigdeezs said:What controller did you get?
Be sure to check on the accuracy of the shunt reading before and after putting the fuses in the path, V drop is likely to have an amplified effect there?MJSfoto1956 said:I really like the PowerVelocity Bluetooth iPhone app with all its great functions -- so what do do? Well, I'm going to add some custom electronics to my mix so that I can get the PowerVelocity Bluetooth app to work in "read only" mode. Here's the wiring diagram.
john61ct said:Be sure to check on the accuracy of the shunt reading before and after putting the fuses in the path, V drop is likely to have an amplified effect there?
MJSfoto1956 said:john61ct said:Be sure to check on the accuracy of the shunt reading before and after putting the fuses in the path, V drop is likely to have an amplified effect there?
This is news to me -- can you shed some more light here?
Thx
M
999zip999 said:You had a P.V. controller and it was noisy ?
fechter said:That controller looks like a beast. :thumb:
I'd be interested in learning more about that one. Do they have a web site?
999zip999 said:Oh and how many fets ? On both ?
999zip999 said:The P.V. is 18fet and QS is 24fet. My guess. Good luck and keep up with your pack.
flippy said:And replace those fuses.....
