As the title says. I have a newly purchased BBS02 and upon first tests the throttle rotates the chainring once; you let go and press again and it rotates again. Same with PAS - cycle half a rotation, get a boost, pause and do another rotation, get another boost.
No error codes on the DPC18 display shown. Battery is a EM3EV 52V battery which works flawlessly on my other ebike with a Mac8T geared hub motor; so eliminated connection issues from the battery at least. Have removed the gear shift and brake sensors to eliminate those.
I thought it might be the hall sensors in the motor but the cables are connected fine.
It's under warranty so LBS will replace motor but it's going to take a few weeks. Anything I can investigate beforehand?
