jay7264
hey everybody i forgot the name of the charger that is capable of charging the cells individual instead of bleeding the high cells down i think it had bc in the name of it thanks in advance
Okay so how come people are doing this with multiple different dynamic balance chargers.You can't use two of them to charge a 12s however you supply them.
It's also a waste of money. You could buy proper ev kit for less. The gains of which are huge.
I'm thinking that you think it's not possible because of the fact that while one charger is sensing voltage the other will be charging. And when there sharing basically the same point on the battery,(let's say 2 6s chargers and 2 6s batteries point neg of cell 6 and pos of cell 7 will basically be the same point) this will cause inaccuracies in the charger that's sensing voltages.I've been using 2 x UNA9 Plus for months now charging my 18S battery. There is no issue charging 9S from each charger. I run them off 2 x EFuel 30A power supplies that are fully isolated.
The standard connection will work but those JST plugs burn out pretty quickly so I replaced the whole output wiring harness with 18 gauge silicon wire and high-mating-cycle Molex connectors. Its easy to get to the output contacts at one end of the PCB to attach these.
And what do you mean "proper EV kit"? Are you talking about a BMS?- Two this UN-A6 chargers could be combined to compose one 12S charger and even share one input power.
diggler said:Okay so how come people are doing this with multiple different dynamic balance chargers.You can't use two of them to charge a 12s however you supply them.
Like for instance the bc186.
http://endless-sphere.com/forums/download/file.php?id=114187
http://endless-sphere.com/forums/viewtopic.php?f=31&t=41107&start=225#p761656
The una9.
But after people have tried with success and say in the end this one minor undesirable doesn't effect the final charge accuracy or time, I tend to belive them. :wink:
The only reason why I'm asking if the una6 plus is capable of using two to charge a 12s battery hooked to one power supply in because it was said here that it could.http://endless-sphere.com/forums/viewtopic.php?f=31&t=41107&start=250#p780739
