GaryTheGolfer
- Joined
- Apr 4, 2020
- Messages
- 1
Hi,
I ended up here directed from Speedict.com's website (?)
My questions relate to using a Neptune 15 to balance an old 10s/2p 36v 360W ebike battery.
Theoretically ebike battery BMSs should balance/rebalance ebike batteries but in practice it seems they only keep a fairly balanced battery in balance. I have a battery that has a variation of about 0.7v across the cells (eg 3.4v to 4.1v). The current cheap BMS can't cope with (rebalance) the cells. (no surprise). The cells have been stored badly for months (even before I got them)
I am considering a 10s balance charger or a Neptune15 Smart BMS. The balance charger may be able to properly balance the cells (assuming they can be saved). The Smart BMA is a much more elegant solution. The Balance Charger is much less convenient. Both solutions would cost about the same. The battery will often have to be left for many months at a time (hopefully, at storage voltage). So rebalancing may be a frequent requirement.
I cannot see from the Smart BMS makers website what range of imbalance the Neptune can deal with. Simply knowing, via bluetooth/app, what the cells voltages are is of no help if that BMS can't fix a badly out of balance battery.
Does anyone know what real range of imbalance the Neptune can correct?
Does anyone know of any other brand/model of Smart BMS CAN correct such a wide range of cell voltages?
Thanks in Advance for any help/suggestions
