Mammalian04
Hey Gents,
I have 2 Q76Rs and a Raptor 140 that need batteries. I probably won't need them at the same time so I mocked up a battery that will fit both frames. 20s11p is about all I could fit comfortably so the battery can be easily taking in and out of frame.
Q76 and Raptor frame drawings overlayed on one another.
20s11p layout - I am open to improvements if anyone sees any.
Q76 Frame
Batteries laid out according to drawing. Ignore the missing cells at the bottom. I ran out and had to steal some from the bottom. I've got more on order now. Also, I had a cell out of place on the 7th row from the bottom. The cell hanging out all the way on the right should have been a row higher, as shown in the drawing.
There is a chance that the battery could squeeze inside the frame above my Adaptto Max-e but it will be very tight if it does fit. The controller inside the frame under the white foam padding.
Q76 Frame
