Long time lurker, first time poster. Need some advice on battery balancing.
I built an ebike as a fun project to mess around with. When it came to buying the battery, I grabbed a 10Ah 36V Vpower pack from an eBay seller in Hong Kong. Charged it up, and the bike works. So far so good. Then, after a few minutes riding, the motor cuts out. Flat battery, already?
From reading on here, I realise that VPower isn't exactly a quality brand, and buying them from eBay was probably a mistake. What can I say - I wanted something cheap to experiment with. Unfortunately, now that the bike works, I've caught the bug and want to ride some more
The pack is almost new (it was bought a few months ago), and has been run only about 5 or 6 times.
It's never gone further than about 3 miles on a single charge, so I guess the pack is not balanced. At all.
Most cells were still at 3.34V when the motor cut out, but there's one at 1.36V. I know that voltage isn't a good indicator of state of charge, but it's clear something is up.
Charging on a 6A charger takes only 10 minutes, which is nowhere near long enough, so again I suspect the battery isn't balanced, and I'm not getting the full capacity out my battery. When the charger is "finished" the majority of cells are at 3.65V, but this one is down at 3.25V.
Leaving the charger to run overnight doesn't seem to help, either.
First of all, is the battery still good? Is it worth trying to balance it?
If so, is there any way to balance charge without opening up the pack (and unwrapping several miles of duct tape that's holding it together?)
Would replacing the BMS with a balancing BMS help? The one that's on there is as cheap as it gets, and I suspect it doesn't do balancing.
