hi.
i've been looking through this forum a bit as well as others to try to find out how to get the most life from my ebike battery pack. if anyone has any advice or can point me to another thread that already answers this then great, thanks. i'm assuming that most 'best practice' ideas will apply equally to my 29E cells as to all Li-ion 18650's.
my set up is 37V 10S 4P pack of 18650's powering an old Heinzmann classic hub and controller and i have a 2A charger. it appears that the high drain of this old motor and controller (its rated at 30A max continuous) is already a factor that will reduce the life of my pack .... so just trying to give it all the help i can...
question's
1 - what is the best voltage to discharge down to? is the 2.8V cut out of the BMS too low for repeated discharges?
(i usually don't take it down past 34/35V ie 3.4/3.5V per cell assuming they are all balanced)
2 - i have read that batteries should not be charged for 90 mins of being discharged. would this be to allow them to cool before applying current to them? any truth behind this as the charge current is way below any discharge rate?
3 - as li-ion's are best stored long term at around 50% rather than at 100%, does it also hold true that i should not fully charge the pack (ideally) until i am about to next use it? this would allow the pack to remain most of its life in a discharged state. if i always charged as soon as i arrive back it would spend most of its time fully charged even if it was only for 1-4 days between any amount of discharge...
4 - should i always remove the battery pack from the bike and bring it into the house to reduce the effects of fluctuating storage temperatures int he un-insulated garage where the bike is kept? ( i don't do this at the moment as it is summer here in the UK. the most extreme temps would usually be between -5C to + 30C)
thanks
question's
thanks
