mxer
Ok, I have decided on a MAC 500 speed motor.....
I'm used to using SLA's due to there simplicity and availibilty to the UK....
I have now found this wonderful site called HobbyKing And have seen many different types of Lipo's at very good prices I can play with...
Trouble is, like i said i'm used to the simple set ups with SLA's running 24v,36v,48, and simple chargers that go with them....
Ok, Lipo's run in strange voltages 3s = 11.1v, 4s = 14.8v, 5s = 18.5v, 6s = 22.2v and so on, strangly all inbetween my simple SLA's..... The MAC kit's can run 36vto48v or even 72v.....So my question is what would be the best way to run the top end of 48 with lipo's or is it best to go alittle higher, I'm only planing on going 5/5.8 AH so only running in series..
Then there is the charging side? I have heard of bulk charging and read a few articals, and would be my choice of the way to charge (charging individually, not really) only to balance every now and again (sounds like you need two chargers then?) Bulk charging at what voltage ? As an example if i had 2 x 6s22.2v in series = 44.4 would a standard 48v charger be ok ? or would it stetch the pack to 48v and cause damage/overcharge?...
After readying this myself I guess I'm after your MAC setups for guidence, what lipo battery setups you have including chargers and voltages and what controllers you purchessed of Cell man etc, There are sooooooo many way's to do things, there must be a standard set up/config that just works really well.....
Many Many Thanks in advance, You never no I may even be doing my own build one day Iv'e been living on this site, It's amazing and so complicated which is what i like :lol:
