m3vuv
Hi all,i have a bionx direct drive hub motor,i need to remove the steel ring with the magnets on it too refit it into a chineese motor body,any ideas how to remove it from the bionx casing,is it just an interferance press fit?,see pic,thats it sitting inside the magnets on the chineese hub motor,i plan on fitting it by bonding it with epoxy or drilling and tapping the chineese hub and fitting grub screws into the bionx steel band with the magnets on,the bionx axle will fit the original chineese side covers,i want to use the bionx stator as the windings are thicker and better quality rather than have to rewind my bured out chinese motor.
