izeman
1 GW
bres55 that's great info, but as far as i understand this, this is "only" communicaiting with the BMS, the same way the android and pc app do it?!
so it's not a try to reprogram the CPU? as this is something that would be really usefull. imho this BMS is really capable, but not the way it works right now.
the K1 switch, as you said, only seems to disable the output FETs. but the BT module is still fully powered all the time, draining the battery.
of course it makes sense to do so, as you need to connect the phone to the BMS, which only works when BT is on. the problem i see is: IT'S ALWAYS ON. it never shuts down. WHY could that be?
as i read it, it should go in standby and wakeup every 10s and look for a connection, right?
