jonnybee_123
- Joined
- Sep 27, 2019
- Messages
- 40
hello,
ive built a ebike using a old bmc v4 motor running at 1500w. while changing the clutch in the motor ive broken a hall sensor cable and need to replace the loom running through the axle ,iv pulled them all out as i could use more length on the cable.
can anybody direct me to a source where i can buy the same multi core cable?
if i cant buy the same cable can anybody recommend a alternative ?
failing these my next option would be to use the cable i have and then joint it in a small box outside of the axle,(but i still need some cable) whats preferred silicon or Teflon coated and size ? im thinking 6mm cable would be fine outside of the axle
