Andrew.Robinson
Hi - I've been exploring this site - great resource.
I'm looking for an ebike - not really into building everything from scratch, but I cold install a kit on a cheap frame. Here in Yellowknife we bike all through the winter, which lasts from Nov to April and can get down to minus 40 deg C (OK very few bike below minus 30). I want an e-bike that would do a 10 km return trip in minus 30 deg C as long as I kept the battery inside before I started. In the summer I would expect the battery to last longer.
Budget - ideally under $1,000 (US)
Here is what I'm thinking:
- cruiser or crank forward style (don't really like hunching over my current MTB handle-bars) - or maybe a cargo - An Electra Lux 7-speed could be a good starting frame, although it is Aluminum - a steel version would be cheaper/better? http://www.electrabike.com/bikes/cruiser/cruiser-lux-fat-tire-7d?g=mens be better
- 4" fat tires - 26"? (that is what is available here)
- geared hub motor with metal planetary gears - or hub direct drive motor (I fear that plastic gears will shatter in the cold)
- rear deraileaur - I don't think just 3 speeds would be enough
- removeable battery
- frame mounted battery (lower centre of gravity)
- torque sensing control (cadence sensor can cause rear wheel to spin out on ice - when starting off slow & motor kicks in?)
- Street legal rules limit motor to 500W / 32 km/hr
thoughts? suggestions?
