If you can post good pictures of the board, both sides, I can probably figure out if it's possible. In most cases, you just need to add a potentiometer across a resistor.
Alan B said:That is why the LED supplies are more valuable and better choices as lithium battery chargers. They have true adjustable current and voltage limiting, as well as being sealed and potted against water intrusion. At least most of them are that way.
fechter said:If you can post good pictures of the board, both sides, I can probably figure out if it's possible. In most cases, you just need to add a potentiometer across a resistor.
You're looking through the wrong end of the telescope mate. I've never heard of one needing to be serviced before, most likely due to the potting used.ElectricGod said:Alan B said:That is why the LED supplies are more valuable and better choices as lithium battery chargers. They have true adjustable current and voltage limiting, as well as being sealed and potted against water intrusion. At least most of them are that way.
Sealed and potted = NOT serviceable.
No thanks!
No thanks!
And that is how your setup could look likeElectricGod said:Sealed and potted = NOT serviceable.
No thanks!
see .pdf10. This series meets the typical life expectancy of >62,000 hours of operation when Tcase, particularly tc point (or TMP, per DLC), is about 75 °C or less.
Meanwell HLG LED supplies are potted and extremely reliable. The HLG's are voltage and current limit adjustable and make excellent chargers with no hacking required.
Thanks. It is just such a nice upgrade, after annoying fan action of previous set-up. Can charge any time, anywhere now.Alan B said:Nice Setup.
You can look at HLG-600H. They are not super cheap but I have a pile of broken standard CCCV chargers that did not got near to a 100,000 hour mark all together and did cost more then MW.markz said:As long as can still get 15A out of it and not cost too much.
They can be, yes.markz said:So them LED chargers by Meanwell are all potted because they are outdoors running LED's ?
You can parallel (and series) as many of the HLG series as you need to for the capability you're after. Cost, well, they're not all that cheap, but they sure are more durable than any other charger I've had, including the Satiator (because they don't ahve connectors on the body to break).As long as can still get 15A out of it and not cost too much.
I have spare S-150-24's only <1A-8A regulation.
In series with generic S-350-48 creates a nice 500w CC\CV charger 54-84V.
DrkAngel said:
DrkAngel said:
That is my next mission.SE series has no known Amp regulation mod ... and will fault if unregulated as charger.
Most guys find something cheaper, like a bunch of halogen light bulbs or old heating elements from a toaster, hair dryer, water heater, etc. The trick is to get the right resistance to load the supply enough to get it into limiting but not so much that the voltage drops below about 1/2 the no load voltage.
DrkAngel said:Make sure MeanWell is set to 110V not 220V!
It can function only once and will no longer be reset after functioned, same as a thermal cut-off. Operating temperature can be arbitrarily set, in contrary with conventional thermal cut-off that has only limited operating temperature. It is excellent in aging deterioration in high temperature atmosphere compared with conventional thermal cut-off. It is excellent in the thermal responsiveness, touches directly to the heat source, and there is a noncontact type that gives the contact type, the heat source, and the clearance used and uses it.
Type Single pole - single throw
Rated Current AC125/250V 17A
Resistive load
Operating Temperature Any temperature up to 260°C can be specified.
Temperature Tolerance ±5°C or more
Endurance 1shot
Dielectric Strength AC1,800V
Insulation Resistance 100MΩ or more(DC 500V)
Circuit Resistance 50mΩ or less
Heat Resistance 250°C
