The specs on their page (quoted below for reference if anyone needs them)
Peak Power
Kalk&, INK& 10 kW*
Kalk INK, INK Race, OR, OR Race, AP 11 kW*
Nominal power
5.8 kW
At the listing of
Voltage (nominal)
51.8 V
Capacity
50 Ah / 2.6 kWh
that means peak current should be 11000W / 51.8v = 212.4A. For a 2.6kwh pack, that's about 4C.
nominal should be 5800w / 51.8v = 112A continuous capable, which is about 2C for the 2.6kwh pack load.
So first, your new battery should be chosen to be capable of at least what the old one can do, so that if it ever ends up stuck running the whole load (old one shuts down or fails on a ride for whatever reason), the new one can handle the load without damage or stress.
This means it will probably have to be about the same size or larger than the original, depending on what cells it's made of, to have the same capacity and especially capability. They dont' say which 18650 cell they used, just "premium", so you'd have to decide what to build it from if you build it, or what to have it made from if you buy one, if you want the same "kind" of pack. You could make it (or have it made) from other types of cells like pouches, etc., but they all require compression so the casing has to be built to do this. 18650s have that as part of the cell so the case doesn't have to do it.
Next, as long as both batteries are at the same voltage at the time you parallel them, *and both* their BMSes have common port designs (same port on the BMS for both charge and discharge, rather than separate connections on the BMS for each), you don't "need" a paralleling module.
Such a module *can* add a safety feature, keeping one pack from draining the other if something should go wrong with it, but their primary reason for use is being able to plug in different voltage packs and keeping them from feeding back into each other.
If they are just modules with a pair of schottky diodes (one from each pack input) then you can parallel multiple modules to allow the amount of current you need (at least two of them for the one you're thinking of, for the currents calculated based on the specs).
If they are something more complicated, such as MCU-controlled FETs such as some of the companies selling these claim they are, then paralleling them may or may not work correctly depending on how they are designed (if one of them shuts off from some crash or limitation, the other one wil suddenly have twice the load it did before, and if it's higher than it's capability, it could just go poof and you're stuck powerless until you disconnect the parallelers and directly connect one of the battery packs to your system.
Another option that isn't as helpful as paralleling the packs is to connect them to a marine or solar battery switcher, and then when you run out with one pack, you can stop, shut the system off, switch packs, then turn on and ride away.
Now, none of this will work if your bike has a system that requires communications with the battery to work. Few do, but some are built this way. If your battery only has two wires from it to the bike's systems, it is unlikely to be built this way. If it has two main power wires and some smaller connections as well, it could be built to require this battery.
Battery
- Cells
Premium 18650 lithium cells
- Voltage (nominal)
51.8 V
- Capacity
50 Ah / 2.6 kWh
- Features
Removable, can be charged when installed in bike or separately. Built in SoC indicator.
Brake modes
- Freewheel
No motorbrake or energy regeneration
- 2-stroke
Motor brake with energy regeneration
- 4-stroke
Brakes
- Brake type
Formula motorcycle disc brakes, four piston calipers, alloy levers. Hand lever for front- and rear brake.
- Disc
Stainless steel, 8.66" mm diameter, 0.13" thickness
Charging
- 0-100%
3 hours
- 0-80%
2 hours
- Charger type
External charger for standard 110 V outlets
Chassis
- Frame
6061-T6 Aluminium, Extruded, Forged, CNC machined, welded and painted.
- Swingarm
Controller
- Features
Best-in-class power density and state-of-the-art motor control algorithms.
Dashboard
- Features
- Kalk INK, INK Race, OR, OR Race, AP
Dashboard integrated in stem with battery SoC indicator, ride- and brake mode selection, warning indicator
- Kalk&, INK&
TFT display with battery SoC, speedometer, odometer, trip meter, ride mode selecetion, brake mode selection and telltales.
Dimensions
- Seat height
- Kalk&, INK&, AP
35.83"
36.46"
- Wheel base
51.57"
- Ground clearance
11.81"
- Fork angle
25°
- Trail
3.44"
- Offset
0.87" in triple clamps, 1.42" in forks
- Width
31.89"
- Height to handle
44.69"
Drivetrain
- Peak power
- Kalk&, INK&
10 kW*
11 kW*
- Torque (wheel)
- Kalk&, INK&
252 Nm*
280 Nm*
- Torque (motor axle)
42 Nm
- Drivetrain type
- Kalk INK, INK Race, OR, OR Race, AP, INK&
Direct drive, 420 chain with O-ring
- Kalk&
Direct drive, Gates PolyChain GT Carbon
- Electric motor type
Interior permanent magnet motor
- Front sprocket
12 teeth chain
- Kalk&
18 teeth, Gates mudport technology
- Rear Sprocket
- Kalk INK&
72 Teeth chain
80 Teeth chain
- Kalk&
108 teeth belt, Gates mudport technology
Fenders & Bodywork
- Material
- Kalk&, INK, INK&, OR
PC/ABS plastic
- Kalk INK Race, OR Race
PC/ABS plastic Front fender PP plastic
- Kalk AP
Recycled fibre-reinforced plastic from Trifilon in fenders and covers.
Handlebar
- Interface
1.25"
- Material
Aerospace grade 7050 aluminium
- Rise
0.79"
- Width
31.89"
Regulatory
- Classification
- Kalk INK, INK Race, OR, Or Race, AP
Off-road
- Kalk&, INK&
Motorcycle*
- Licence
None*
- Kalk&, INK&
M1*
Ride modes
- Explore
The ultimate mode during exploration. Limited to 28 mph with 3-4 hours of battery range.
- Explore
Enduro or active trail riding. 1-2 hours riding time
- Excel
Track and race mode, maximal torque and speed, riding time up to 1 hour.
Speed & Range
- Range
- Mixed city riding (WMTC-II)
53 miles*
- Trail/Enduro riding
3 hours*
- High speed riding (43 mph)
22 miles*
Stand
No stand
- Kalk&, INK&
Side stand
Suspension
- Front
- Kalk INK, INK Race, INK&, AP
Upside down MX spring forks with rebound adjustment, specially engineered for Kalk. Travel 7.87".
- Kalk&, OR, OR Race
Öhlins upside-down air forks featuring 1.50" stanchion tubes for extra rigidity and strength, specially developed for Cake. Adjustable for high-speed compression, low-speed compression and low-speed rebound. The forks are equipped with Öhlins advanced 3 stage air springs with individual setup for ride heights and bottoming resistance. Travel 8.03".
- Rear
Direct mounted shock for simplicity and robustness.
8.07" Öhlins TTX22 shock with CAKE internals and spring. Used with linkage for optimal performance.
Weight
- Dry weight
- Kalk INK
132 lbs
- NK Race
134 lbs
- Kalk OR
115 lbs
- Kalk OR Race
128 lbs
- Kalk AP
139 lbs
- Kalk INK&
146 lbs
- Kalk&
137 lbs
- Max. permittable load
397 lbs (bike + battery + rider)
Wheels & Tires
- Hubs
Forged and CNC aluminium CAKE hubs with 25 mm axle
- Rims
- Kalk&, INK, INK&
19"x1.85” custom designed 7116-T6 aluminium motorcycle rims
- Kalk INK race, OR Race
Front, 19"x1.40" aluminium mx rims Rear, 18"x1.85" aluminium mx rims
- Kalk AP
Front & Rear, 1.85"x18" aluminium rims.
- Kalk OR
24" (bicycle standard) re-inforced, triple chamber, 6061 aluminium.
- Tires
- Kalk &, INK&
19"x3.00" dual sport motorcycle tires
Front, 70/100-19 mx tires Rear, 3.00-18 mx tires
- Kalk INK
19" off-road motorcycle tires
- Kalk OR
Custom made 24" lightweight off-road tires for durability and minimum trail wear.
- *Disclaimers
The street legal bikes are homologated for the specific country the bike is delivered to. That means that lights, blinkers and other "street legal necessities" might differ in look, style and dimensions, everything to meet the local regulations. Accordingly, details might look different from the product photo. • Images show fully specced vehicles. • The specs, such as range, speed and power are not estimated by CAKE. The numbers are the result from the European homologation test, WMTC-II. (performed in a controlled environment and might differ from regular use) • Peak power is the maximum power the power supply can sustain for a short time. • The actual energy storage capabilities of the battery can vary from the nominal rated capacity. • Torque values based on motor specifications. • Charging time may differ depending on the voltage in the local grid. • All specifications are subject to change without notice. • It is the buyer’s/owner’s responsibility to ensure all local rules, regulations, classifications and license requirements are followed.
