Several issues discussed with RC Astro 3210s;
1) Y-pedal found his HV160 controller ran hot at cruise and had to open the throttle wide open or close to wide open to keep the heat down,
2) Belt slippage, system flexing, and torque shock are expressed concerns,
3) and from MWKeefer:
[*At 44.4 volts the motor RPM (assuming minimum 90% efficiency) would be: 5394.6 RPM
Astro specs list the best amps on this motor at 17 which with the Kt (if accurate) is wrong... 17A would give you 170 Kt but the same docs claim best motor efficiency at 93% and 190 in oz, that would be 19A right?They claim the figure of 375 in oz above 90% efficiency so... Using the Astro provided Kt: 375 / 10 = 37.5 A, close enough to the 38A you specified. Astro also claims a peak of 500 in ounces of torque for up to 60 seconds... this is interesting, 500 / Kt = 50A. Now we have a max nominal power of 50 * 44.4 = 2220].
My question is, "If the 3210 developes its' power in a range of 17amps to 50amps, the Castle HV controllers like to be run at full power, and over throttling raises stress issues; wouldn't the HV60 amp controller be more suited than the HV160amp?" Or, why does an Astro3210 need to be fed 100+amps?
I believe there's a deeper answer, but could folks be running the HV160 for the big power while the smaller HV60 would yield a more reliable albeit more modest power?
This thread is even more theoritical as I just read recumbence thread as to HV160 and now I can't find the delete for this one
