Just wanted to check with the community knowledge if there is any reason for cell level fusing other than internal shorts?
My thinking is that in this event the 'fuse' will deal with a huge current. Lets say in a 9p pack you are easily talking hundreds of amps (If I am correct to assume that in the event of a shot the entire pack dumps its shorting current into that one battery).
Therefore when choosing a fuse should the main requirement to choose one that blows/fails as close as possible to the upper limit you intend to draw from each cell, or simply one that blows well below the potential short current?
So, in a given example:
I wish to have an upper limit of 15A from each individual cell. As it's readily available, I choose 0.2x4mm nickel tabs as my fuse connector, with a rough fusing current of 20A (useful table, purely on the maths, not tested:https://docs.google.com/spreadsheets/d/1TKznS77--MO6bC9H0BMu434ZRykqB8wwDxQFHpXDhHM/edit#gid=0).
Lets say the 20A fusing current is way off, and the nickel carries upward of 50A before blowing.
Is this now a problem? By my thinking - the failure it is protecting against should blow the fuse even if calculations are way off.
I think I see the obvious answer: that the momentary 50A short into that cell stands a higher chance of causing thermal runaway that 15-20A would. But if this cell has shorted would this not be a likely event anyway?
This is all with the question in mind: Why bugger about with fuse wire (which on 15A wire has a 15-30 or so amp blow range anyway) when you can just use easily weldable nickel strip.
