Nice mod :thumb: Contact us if you need spare parts, we have stock of old motors front covers and some other parts we can send you for the price of shipping
Thank you for the offer, I appreciate your help!
BTW what kind of rear chain guard do you use on the 161? All the ones I find online would need a rework because the width is to high for the narrow 219 chain... One solution would be to mill the middlepart down from 24mm to 16mm or something.
Watertight plugs, experimental rear chain guard and new sprocket cover
Another thing on my to do list, was to exchange the hall and temperatur connector from motor and controller. Initially I used two standard servo plugs to get it to work as they are small and I had them lying around. Now that my plan is to make the bike more and more resistant to water I changed them to watertight 6 pole connectors.
Before:
After:
I also decided to cut off the plastic XT150 covers from the phase wires as they already came loose and weren't watertight anyway. To secure the contact I plugged the bare connectors together and heat shrinked it.
As the controller and motor were already out of the frame I disassembled all the plastic covers and turned the bike upside down to mount my experimental rear chain guard.
As this project started I used a small 63 teeth chainring on the rear and could therefore use the original rear chain guard the bike came with. But as I went bigger with the gearing I couldn't use the guard anymore so I sawed off the welded holding brackets.
But this resulted in the problem that the chain wasn't aligned anymore before hitting the chain ring and therefore jumped off sometimes. Especially when doing a 180 degree turn with one foot on the ground.
For testing I 3D-printed all the parts.
Test fit looks good. Real life test still on the to do list.
As I already had it upside down I also made a aluminium cover for the bottom side of the battery housing.
Then the reassembling.
Cable management looks very clean now.
Chainline from the side
I also made a new sprocket cover since the old one broke from a slapping chain.
As mentioned in my last post I use drilled out M6 nuts as bushings. So I can really tighten up the two M6 bolts without worrying about the plastic. The bushings are pressfited and also glued.
