Good morning,
I have a Chinese stealthbomber, and I'm down, I can't perform an angle calibration on the app. When I open the app and I connect in bluetooth there is the message lack voltage, and on the first page everything is at zero. When I turn the throttle the motor turns but vibrates strongly and then it goes into error with 8 flashes at the controller LED levels. I traveled 4000 km with the bike, also the cables that leave the engine have oxidized and completely deteriorated, I replaced pieces of cable but I did not have the same section ² as the original, it is a little smaller. The cables are all well connected (front / rear brakes, throttle, and shunt on the lcd) lcd is ukc1.
So questions do I have to dismantle the motor and change the cables at the base? Is the section important as long as the cable supports 150 ampere 220 v? Why do I have no values on the app? why can't I run a calibration? thank you very much for giving me help
