Experts,
I don't know if concurrent or independent charging is the right term for what I am going to described, the fact is that neither serial nor parallel applies....
My new electric scooter will be based on a 20S LiFePo4 battery pack with following cells:
- 8 winston 40ah brand new cells
- 4 sinopoly 40ah brand new cells
- 8 wina cells savaged from an old pack with a measured residual capacity ranging from 39 to 51 ah
So the pack is going to be very dis-aligned from the beginning; so I am aware that no standard BMS will be able to align it.
Therefore I am thinking this:
- forget about BMS, I will constantly monitor individual cell voltage and stop riding when close to low-voltage-cut-off.
- when I need a fast charge, use the 20S 72Volts LiFePo4 charger connected to the serial pack; with a circuitry that will stop the charge as soon as the first cell reaches 3.6Volts
- when I have time for a slow charge, I will use a second charger which is actually a set of 20 independent 1S LiFePo4 chargers, eachone connected to its own cell of the pack; the 20 individual chargers must be of course electrically decoupled. This way I will be able to charge to its full every single cell and I think it will be pretty safe to charge unattended as long as every individual charger is able to disconnect as soon as its own cell is full. So I can safely leave it for an overnight charge.
So the problem is how to build these 20 chargers? They must be small, cheap and simple; from a first scouting I found the following:
- http://www.ebay.it/itm/1000mA-LiFePO4-Akku-Laderegler-Lademodul-mit-Schutz-1S-3-2V-mit-Micro-USBa-Bucahse-/351920139313?hash=item51f0132c31:g:yG0AAOSw4GVYPaVD
This is indeed small, pretty cheap and fully-fledged charger with also LED status, only thing I need an extra 5v power source per unit
- http://www.ebay.it/itm/3-2V-LiFe-LiFePO4-Rechargeable-Battery-Charger-3-65V-1A-DC5-5-2-1mm-EUS-/221876225660?hash=item33a8da867c:g:9MUAAOSwyQtV66nn
This is complete of 220V ac/dc converter, so I just need to buy 20 of them and I am ready to go!
What do you think about slow charging this way?
Any suggestion on the small 1S charger?
Thanks,
Luca.
Thanks,
Luca.
