I've only used Lipo and lithium ion which are easily balanced and SOC determined by voltage.
I was looking to build a large lifepo4 pack for my hybrid car and when testing a couple of lifepo4 cells I am learning that they do not behave like your typical lipo cell. I'm am concerned about using this chemistry for a pack.
The problem is that the voltage stays almost exactly the same through the discharge.
Here are some of my questions.
1) Will lifepo4 cells in parallel balance between each other to the same exact SOC?
2) Can a BMS balance the pack (the different parallel groups) to the same SOC? or do they only prevent a cell from going under 2.5 volts and over 3.65 volts?
3) I plan on building a large 480 cell pack, will I have nothing but problems with balancing and charging the pack because I do not know the SOC?
4) Will I always have to charge the pack to full or close to full voltage because there is no other way to charge it to 90% because you can not determine SOC?
5) Should I avoid using a Lifepo4 pack because of these issues? Mainly, not being able to balance the cells and not being able to determine the SOC.
Thanks.
Thanks.
