Magneto
1 W
Hi Guys,
Was hoping to get a couple of clues as to what may be wrong with my controller on my e-bike, it's a 'Greenewheels' very similar to the Wisper bikes. Controller model no is KT36ZWP.
After about 10 mins of riding, under a decent load going up a hill, the power starts backing off then stuttering at a particular frequency, (maybe 5hz?) this is not frequency is not speed related oddly enough. This only lasts for a very short time, it gets worse then shuts down all power to the motor (a brushless geared bafang). After a short wait it will fire up again without re-boot, but has little in the way of power output until the same fail scenario happens all over again. Re-boot will re-start sooner than waiting for it to fire again.
Have checked the halls, all ok even swapped them out to make sure one wasn't failing while warm.
Sounds like overtemp shutdown, although I would expect this to be a smooth tailing off of power rather than being jerky like this.
Have checked FETS, all 6 all look OK, and integrity to heatsink was OK, checked. tightened them and test rode again, no sucess. Re-soldered some of the joints, some pretty bad soldering on this board, so I guess I might try some more of that, but could be a partially dead FET??
Maybe a FET that has lost some of it's shunt capacity through melted solder inside the TO220? Maybe one of those mysterious surface mount controller chips is failing when a bit warm?
Any clues would be very much appreciated, as finding a replacement that has the same connections, features and LVC for a LiManganese 36V may be a challenge, was thinking ecrazyman's 36V 350W unit.
