I got an controller 48-80V 80amp 18mosfet drive.
I got problem with low voltage circuit. Its a typical switch strepdown circuit. With mje13003 and as78l05 an 2.2uf 100v cap, 1 25v 220uf cap, 1 16v 220 uf cap.
The 5v is getting 1.5V.
The meashure is done with only battery in and nothing else connect exept vcc power on.
The mje13003 was first at 6v on VOut. I changed resistance from 100ohm 1w to 200ohm 1w and now got 7V out. So 7v in and 7v out.
Further I got 7V in to transistor as78l05 but here is where The voltage drop out, and in circuit 5v+ it shows 1.5V.
I have spareparts and different capacitors ceramic/film/electrolyt etc avalible is there a better choise to use in circuit?
Is there a better choise on caps to use?
I did change some caps with same value but these are small and it could be possible they got damage from heat with solderering.
Anf one more thing I did put The selflearn wire when 60v battery was connect and now i hot 48v connect when troubleshoot.
Please advice on caps and if theres better ones to use.
And whats to be the most logic part to fokus on.
I got an fluke 177 to take numbers from.
