syco26
Thanks again for the reply. I will start the hunt and get back to you.
Yes all the previous tests were conducted on the wire loom in the above photo without the throttle connected.
Something I totally forgot to mention, as too focused on the controller and loom, the blue and red wires sitting to the bottom in the above photo goes to a little LED head light. Unsure if this would be adding to the issue somehow?
Also when my mother in-law first asked me to look at this I found the below issue with the main controller plug. The positive from the charge port had seen some serious heat and the individual socket had snapped off the plug. This was along with the busted spring perch in the throttle.
I replaced the plug and repined it then pulled throttle apart and “rebuilt” the spring perch. I put it back together and it all worked until the spring perch snapped again and busted the wires off the hall sensor. Later found out the reason the throttle spring snapped a second time was from my mother in law twisting the throttle forward to go forward .
As it is taking charge and was working after the plug change I didn’t think this would add to the throttle issue at all but thought I better mention it just in case.
