Well, my instructions show 7kmh as minimum engagement speed, and this is how both of my previous (similar) conversions worked.
I had actually, figured out how to set the wheel size to match my 26" wheels. Pretty basic....
The biggest difference in the installs I've done successfully previous to this one, is regarding the PAS sensors, and the newest install is a 1500w motor where the previous were 1000w. The previous installs used 8 magnet sensors (probably KT manf/supplied) and ran well with C1 set on 01. This newest has a 12 magnet setup (that was already on the bike) that would not work with C1=01 as the previous bikes did. PAS was completely inop. when set that way
So I set it using the "reverse 12 signal" as it has 12 magnets, using C1= 07. With no other changes made, PAS was now fully functional, or it seemed that way at least.
When I started messing with the cruise, I didn't think it was working at all, so I double checked to make sure it was enabled (C7=1), which it was. It wasn't until it occurred to me to try engaging it at higher speeds with the rear wheel held off the ground that I discovered the cruise worked fine - starting at 20mph - WAY over the suggested 7kmh minimum.
Because of the difference in the PAS sensors I was using, I tried C1=05 (thinking 6 magnet signal may help), with no difference. PAS worked, but minimum cruise engage still 20 mph. On a lark, I tried C1=06 (reverse 10 signal), and my minimum engage speed dropped to 15mph, leading me to believe I was getting close to the actual issue, but I have yet to get it any closer.
I am not sure of the "forward signal" vs. "reverse signal" significance to the controller. Forward signal uses 00, 01 (which we know leaves PAS disabled), and 02 for parameters. Reverse signal uses 05 through 07.
I'm also not sure of what is meant by a PAS "locking in". Are you talking cruise will engage at those speeds? My PAS is working as soon as I start pedaling.
Thanks much for the input/ideas. It's surely appreciated.
