fluid2150
Ok, im looking for some help please. Purcashed a 4060 and hooked it up to
my 18fet lyen controller, on 24s lifepo, so 80v nominal. no grinding on noisy,
and fantastic tourque. pull 4.5kw from start, and feels great. But when
my friend had a ride and when he went from stop to start. the hall sensors blew.
now, never had that happen. plus when i took it back to the seller, he said
it could have been wrongly wired. because top speed should be 80kph.
max i could get on a straight was 65, and thats flat out.
keywin setup was 60amps current and 100 phase. i was told the pase
should be 2.5 times more than the current? true? so the seller thinks that
the phase wires and hall sensors were wrongly connected.
Any opinions? can some please help at the color code. i had it working, and felt
fine. 3.5amps no load with woh. tried lyens code and worked backwards
the a 5x series code and that worked, but blew eventualy.
This is my first crystalyte, before then, ive built 2 other 9c bikes.
So question is. wrong code color? bad motor? bad keywin settings? or just pushing
it to hard!
any help would be much appreciated as i get the motor back today.
Thankyou
it to hard!
Thankyou
