Cycle Analyst v3 temp sensor values
eCruiser3k
Hello
I have Mxus 3k V3 motor and I wondering can I use these temperature sensor values in Cycle Analyst V3:
"Linear type
0.39V
186.9 Cdegree/V"
By using those values CA showing outside temperature for cold motor as it should and when I driving around and accelerate temperature rising.
What I have noticed, normally peoples use values:
"Linear type
0.67-0.69V
186.9 Cdegree/V"
But in my bike CA shows temperature with those values for cold motor -37 Cdegree so it is absolute wrong. Temperature is now 16 Cdegree outside where the bike is.
So if somebody can confirm that my values are close enough for use. Mainly that 0.39V?
iirc the first value is what makes it correct at nominal temperatures.
then the other value is whatever makes it correct at more extreme temperatures at either end, while stil being right at nominal.
i forget which ntc or ptc is in the v3 mxus, but the main thread for that should say somewhere in it.
i think there's info somwere around here that says what values in teh ca to use for this specific sensro.
