cyclone fan MOD 4800 watt motor and Gt it1 frame
Bad news. I was adding fOr the last time more sealing for oil.
When tight up bolts hard .
My motor mount crack in a bad place
I need to redone again 😡 so much money
This time I need bullet proof glass..
It looks OK nice before it cracked.
I need try find 3d scanner.
I was hoping to test soon. 😭
Thank you all
Hi all I got my motor mount glue back..
I used
Acrylic glue .
I hope it hold .
To give me time to work out how to make a other better this this time.
Wood or I like clear plastic.
And yes use I use 20mm Acrylic x2
Is 40mm. I look at 3d scanner then I would be able to 3dprint it?
What the best for this
Thank you all
Hi all I fixed my motor mounts. Use hot glue to help
For a test . I did not have My big vesc so I found a big hill. To ride down
To my shock it pedals very well low speed. And hight speed
I use n.o.s 3.0 tires.
So this like a 29" wheels set. Once I got speed I was able ez add my own power in 6 gear. Of the 8 speed I have
My guess the gearbox is good to 70to 85 km then pedaling is be useless.
Waiting for 30wight bellray oil I never try this band
Thank you all
Hi, please, can you give me dimensions of seals needed for gearbox oil mod? I changed gears in gearbox to steel after failure and I want to try make it quieter.
Hi all has for oil seals. I never keep info about seals before install them . the bearingand seal shop for got some for me
All I know is out one I. D seal is 20mm Output shalf
The iner seal only 1 lip
Just
Rebmer I charge the bearing from 12 mm to 8mm hight only charged the out bearing
To fit seal it's 2 lip seal.
I add 2 bolt hole to add oil. I end up not use big o rings I just some gastes sealer From motor bikes
It rubber based. I did not have the room
Were do find steel sun gear for cyclone 3000/4000
I can guess why you blow out old ones . Crazy try 9000 watt not cooling..
Thank you all
I will add a chain gluid for back chainring to help stop come off..
Paco cyclonebike@gmail.com offered me steel gears. About 70USD included shipping to CZ. They use them in new 4800w cyclone motor.
I hyve my setup with sabvoton 130A battery and 290A phase and temperature sensor. Controller limit power when overheated. I'm thinking about electric fan for better cooling. Maybe in summer... :) Now overheating is not problem.
Hi all I been look at better gears.
I found from past es posts .
That people say to try use TORLON.
I dont have tools to Cut it . I like try make some
I can't do cnc .
So Daves gearbox to hard to make gears. By hand
I try for mini cyclone and 3000/4000 motors.
Say cyclone OK motor it not a 3220 I can tell you I get about 10percent more range with it. .
I never use plastic Gears before . I need to know What lithium grease /oil bath
I need
To save gears
Any help for what lithium would be nice
Thank you all
I have one set of 3d printed gears made of Taulman 910 alloy. I think, 3d print from good material can be a way.
https://photos.app.goo.gl/ecMfHpTykVQWQbjp9
But not tested yet. Steel gears arrived to me faster then printed and they are not as loud as expected.
Hi all great some one made sun gears for cyclone 3000/4000 motors
Are you able to sell or share file? Or sell them if so what cost ?
I was Look the them close At pics looks like You need a cisclip grove top and bottom.
Or are you glue them in?
I did notknow you could get 3d TORLON
I find the baering and seal shop. Invoice
Seal are
20x42x7 Tc oil seal
17x24x3 oil seal
Big o rings nbr 70inperial
And one bearing 20x42x8
Hope it helps Thank you all
https://drive.google.com/open?id=1IOzDhmmYX8duprDSB2rKERPeYx2jcL6K
No problem to generate gear. Its M2, 20 degree angle. I made it stronger. 18mm instead 15mm original to better strengt and it fit in gearbox. Inner hole I made 27,8mm to press bearing to its place. No need lockring to fix bearing in its place.
I used this app:
https://gears-3d-printer.en.softonic.com/
You can print via https://treatstock.com
I recomend nylon strengted by some composite like Nylon with carbon fibre or Taulman 910 alloy.....
And idealy 100percent infill.
But not tested life of this. I test only one from PLA fillament with 20 percent infill(bad material to this aplication) to test model and it works but lasts only abou few kms. Better then expected. :)
Hi I don't know what you mean by the wrong way.?
I don't have standed gearing .
This sould make bike go faster.
Trade off. If I am right not the best climber.
Once I tested it. I can. Change back wheel to fix climbing speed.
Change again gearing 13 t motor freewheel.
And not a half link chain
Should climb better
Has my leg input via gearbox
Any help would be great thank you all
Hi all I was. Work all day to test ride my ebike..
With no sparts.
ItS rianing good. Not rideing . Walk of shame to costly
I try oil mod no leak so far.. I use about 200ml if oil it was noT full . Inject it via bleed holes
It sound very different.. Like 2/3 the speed
It sounds slow 😎 it not...
Only thing to worked how wire c. a 2.2 from control 😥
Wait to test 3dprinted gears and big vesc And new fan. It blow not suck
Update I test ride to burn battery . Weird thing
C. A 2.2 show more burn then hoppy king matter.
C. A say 3.5 ah
Hobby king matter say 2.5 ah
Which one it right??
It very cool ebike you can't hear Till use full power.
My gearing is too slow. I know can 65teeth From shop . For quick fix.
EBay I get a 47teeth How small can you get in#25 chain rings
Thank you all
Hi after riding wet weather. Not the best for testing ebike.
All I can say wow.. Once I up grade my spring.
From 350 can get 700 pound. Bike will be done
New 30 wight oil feel great. When done you hard to hear motor when rideing you needto look to see it moving .. Note To my self I use 1.1L of oil
I do burn out from a stand sill. Or wheelie if not careful
Am Not I try .I am running 12s. . If was using 18s my gearing would be good. Past car speed
I may use a 70t teeth? For back it unlike any other bike owned.
Right now back it 81t
May go back to 14 teeth freewheel
I find found better quality one in my bin box new
Cyclone 14t stock freewheel is cheap... And can break.
Unlucky was Not able fit new 14t freewheel no choice to use dicta14t freewheel and halfllnk chain .
It fit nice .i given it a hot oil bath
To clean it and lube it
You can keep paddling at hight speed.. 😆
Can't wait to try deta in big vesc
Thank you all
Hi all tested new gearing. Wow this thing sounds like a nongeared hub motor. 😇
Had a very close call to crash. Ride up a hill next sic bump power. I was half way a cross road
I run over my own leg and sill rideing no stopping
Looks OK like a got a small a fewdrops oil leak only when motor get warm. Hand test motor hit 40c
New fan sould cool down more.
I add vent ports for air when I changed sun gears they been made now
I may use 75teeth for back wheel .
My c. a 2.2say I get like 8000watt which bull shit.
I tust my hobby king matter now..
I get range test no bad about same my 3220and Dave gearbox but hell alot less noise..
I was ride this on a trial you will not hear me past you 😋
Thank you all Es members for help to make great a ebike
Hi all. I been push it. To my shock it never failed.
No use halls
Dose not get hot I lost Alot oil now
I sand test it. Wow all I can say it has tox to drive over dry sand. 🙏😎
The last ebike could that was dual cyclone mini It had halls
And not for long.
I can't wait to try new parts come in post next week.
End up have use 67t with #25 chianring I start to lose tox I can feel it.
I need a full disc or 4 bar to be able mod and for it my hub
I may try 1.1 gearing. If cyclone OK for hills I keep it.
Look at make a new battery. Custom made for this frame. That means I use dual battery.
New vesc I start off at 120 phaze .
I now know cyclone 3000 has a limit. 150 phase.
New fan sould help cool it.
Keep watching soon I happy with ebike I upload video.
Thank you all
Hi all great day.
Got my new Big vesc with blue tooth . I can use phone to replace c. a and use A phone For data
Order new parts 15teeth freewheel 3 paw
700 pound spring big I could find
Change rear chainring for 3 time use 65teeth #25 this mean 1.1 pedal gearing
I fear if my c. a right
I may get some like 10000 watt
It a bit bigger then my 6 Fets mini mosters.
Which I am haveing hard time to believing I get 6000 watt up a hill. From 700watt in less then 1sic
Use my mini mosters
I found out my oil leak bad not From the big sun gear. But my inside seal. 1lip seal
This means I try to upgrade to 2 lip seal.
I uninstall suck fan to a new blow fan.
This may help to stop oil leak has bad.
I got a 2 lip seal 17x24x4
And made a lid for big vesc to cover hole.
Thank you all
Hi all looks like I able to upgrade motor to new cyclone motor 4800 watt.
Has it can fit in my custom motor mounting for this frame
I am work out payment and post cost Now
My. C. A 2.2 is crazy not moving say I using 8000 plus watts.
Limting dose Not work.
I now have a big vesc waiting for waether to get better I hate testing in rian
I hopeing my phone will replace a c a for data
With big vesc
New gearing when down to now 60teeth. Need custom work every time I try new gearing
Smaller 25# I know of is 47t can't find on ebay.
I know get one when change to 4800 watt motor.
Or I may change the motor shaft. To fit fan inside motor now. I change shatf to Ti to cut down wight and make new end cap.
I may cut out wire from motor and rewire it to higher temp wire. 180c
At this stage. May try find better magnet.
Say hollo to astroflight 3320 motor
Big vesc may hard time drive that
Thank you all
Hi all I when around to my bike shop . I got broad
Plus need end for wires for big vesc I got wrong nuts.
I got the hardest spring I could find for 3.25" shock
I was think it too soft. After a few car park hops.
It may be to hard.
I had this before only once you test it on a track.
Can you know how it feels
Thank you
Are you sure you need the big motor? It only makes sense to upgrade if you have over 60a.
Hi all yes looks like I need more copper in a motor if I want to keep it cool.
I will offset wight to change steel motor axle. to Ti
So a cyclone 4800 watt motor with most likely wight the same Cyclone 3000 watt when I done
My big vesc can ez push 150amp at 12s
More like 300 amp
This bike is able to do Rejen brake if I choose so.
Very rare for mid drive.
5 mins to change it
I take me 2 months to save up to buy. The cyclone 4800 motor.
Yes I have more powerful in runner motors .
I have to buy alot ebike parts this year.
Big vescs are 1 on my list to upgrade all bikes
Thank you all
