Daly BMS dosent connect to bluetooth
MXE
Hi all,
I do have a Daly 20s 200A BMS for my battery.
I also have the bluetooth module (the new one with the button).
I did activate, and everything worked fine. After a while the blutooth shut off automaticly.
From my understanding (what i resarched) the bluetooth shoud aktivate when i cahrge the battery. But this is not happend, i never pop up on the BMS App.
I did resarch for the problem and saw that somtimes the green wire see 0.0 voltage adn then it dosent work anymore. I did open the battery and checked, but the voltage was fine (3.3v) So i pushed the button and all was good. After closing the batterycase again (a lot of work) i had the same problem agin.
Any advise about the daly BMS about bluetooth connecting problems?
Regards, Breth
Hi all,
Regards, Breth
I have the same problem, how did you solve it?
