Rassy
Last month I purchased a used EZ-3 SX trike and added a Bafang 500W 48V crank drive to it. I'm using a 10AH 48V Ping LiFeP04 battery that I already had. The mechanical installation was straight forward. I removed the entire front derailleur so there are no chain guides up front. The rear 7 speed derailleur shifts to any gear and because of the long chain there are no chain issues.
I got this trike for two reasons. First, my brother that had a stroke 7 years ago now lives in Florida and none of my tadpole trikes work out very good for him when he visits. Following his stroke I purchased an EZ-3 SX trike for him which fits him good and he really likes and rides regularly. Also, my tadpole trikes either have no adjustment or very little adjustment to accommodate other visitors, whereas the EZ-3 has almost infinite seat adjustment.
I first stuck a C965 display on the trike, but the handlebars are too long and I couldn't place the control button near the end. My brother only has the use of one hand/arm so it was important to place the control button near the handgrip. So I installed a C963, which worked out great, except this unit does not display miles or MPH, only KM. I'll probably add an independent bike computer.
Edit: The battery sits in the ammo box on the back of the trike.
Edit: Those of you with sharp eyes will note that the C963 display is on the left side. My brother only has use of his right hand, so the rule will be he either picks no assist (he can pedal okay with his feet strapped to the pedals) or level 1 assist when stopped. On the right side, the brake lever is the standard one with the e-brake in it (The right brake lever has a parking brake). I also added one of the e-brake green buttons to the right side so he can temporally cut power.
