description of naming for Votol controllers and how to identify functions
raglinski
Łódź
Hello, I have a request, I want to replace the controller due to the fact that I rewound the motor from a delta winding to a star winding and unfortunately it does not want to work with my ML7260, and this is the version without S. That's why I want to switch to Votola EM100, and here comes the problem because there are versions with the note G, T, 4SP ect. I already know what S means "self-learning", P "cracked version" - does it mean that it has unlocked speed? And what about voltages, because on the slides they say that the EM100 works up to 108V and you can even see on the screenshots online that there is a choice of voltages. Currently I have 60V and I want to switch to 96V. And I need Can-bus, I want to connect the BMS-controller-display using this protocol. From what I found out, the SP version has Can-Bus, but not communication. I'm doing a little modding of the entire structure XD. Thanks in advance for your answer.
