Upgrading my Yuba Mundo to disc brakes, I opted for mechanical BB7's that get great reviews for ease of adjustment except for the inside adjuster wheel. Starting with the front wheel, the brake kit went on easily but I quickly ran into a clearance issue with the inside adjuster - the BMC motor blocks the torx adjuster on the 185mm rotor (a 203 wouldn't quite get it clear either) and the adjuster itself is virtually impossible to turn by any other means.
The mechanism is comprised of a round plastic adjuster wheel that snaps into a retaining groove and engages an almost-hex shaft from the threaded inner pad adjuster that protrudes through the center of the wheel. Turning the wheel turns the shaft and screws the shaft and pad adjuster in or out. There is a torx head in the end of the shaft as well. The wheel also has 6 little grabbers that click in detents around the edge of the retaining lip to hold the setting - the wheel clicks from one detent to the next when turned.
Although the unit is optimistically designed to allow adjustment with the wheel , it's really some kind of cruel hoax - essentially impossible with fingers and no good means to do it with tools that won't soon destroy the wheel. Sadly, the torx head is the way to go.
( ...so this is source of the complaints... :-( )
I fabbed the little tool shown below from a scrap of 1/8 aluminum plate, although a similar piece of PVC or ABS plastic might do as well. The hole is exactly 1.250" and was bored with a Harbor Freight step drill that gave a perfect fit with no dressing. The six little recesses were filed to leave room for the little grabbers to move out of the detents so the wheel can turn.
The tool works great - slip it over the adjuster wheel between the brake and the motor and squeeze a bit - it gloms onto the wheel so it can be easily clicked in/out as needed. Anyhow - it's a workable solution if you find yourself with a similar clearance issue....
