each board is only monitoring and balancing, the master could control a relay and have hv/lv cutoffhardym said:Well thought out layout. Looks like monitoring and balancing with no LV or HV cutoff?
the board will cost me 3.5 in parts at qty of 10zener said:How accurate are they?
I am highly interested in something like this. If it would be available in (ready to plug) for arduino and cheap from asia.
yes it will, thanks, will be making the resistors larger to negate the effect, but balancing should keep it ok if it is used regularly, eg a 10Ah would take a year to discharge. would it be worth wile to have the same / close to even current draw?circuit said:It will have uneven current draw from cells. Beware.
