@blindnas: I suggest you to buy an helmet in case. It will help (a bit) if you fall, especially when doing speed tests!
@squad : hey, an advice from you... I am wondering if a good mold, DIY vaccum enclosure (with no leak) with a domestic vaccum (with good suck power) and a good heatgun... I could achieve good results with Kydex 2mm. Challenge will be to keep the whole area (30x30cm sheet) at the same temperature to ease the molding, nevertheless I think that by continuing to heat the sheet with the heatgun on some difficult areas could help.
I don't plan to use a oven to heat the sheet, just quick and dirty way.
is it something that worth ? epoxy enclosures are fun but I want to give a try to Kydex (8,50e the 30x30cm sheet in France, or ABS).
