Hi guys
Im in the middle of wiring up my APT chinese controller and learned that their software missing in action. There are some links of the program but either the version is glitchy..or doesnt boot up at all. Its the risk i guess i volved.
The contoller also has no bluetooth.
I sucessfully got everything wired up and function without being to see my power levels.
The main problem is that the motor is running perfectly but in reverse. I tried switching some phase and hall sensor combinations with no luck and then decided to jus connect the Reverse and Black negative wires from the wiring harness together.
Now the bike is running in the correct direction but i wont be able to use that reverse function since the wires are connected together, which is ok since ill rarely need it.
Will doing it like this harm anything?? And will the motor work at 100% top speed with the wires connect compared to unconnected?
The motor i have connected is inot on a bike at the moment to test so i was just turning the throttle at 5%
Usually on other controller such as sabvoton..you can go i to the app and change the motor direction using 0 or 1 value but im not able to.
Thanks!!
Thanks!!
