My goal for this build is to have similar geometry to my downhill bike (2007 kona stinky), but have the same power as a small dirtbike. I ride downhill bike a lot and it would be awesome to not have to hike back up after each ride!
Stuff I have purchased so far:
30AH 88V lipo from Hobbycity
4 chargers from Hobbycity
4 meanwell power supplies
2 HXT 80-100 motors with upgraded bearings and re-glued magnets
2 Lyen 12 fet 4110 controllers
Monster T forks
24†downhill rims
4 piston hydraulic brakes
questions
1. Will I have to worry about the tire slipping on rim, is a rim lock necessary?
2. Is there a risk to using regen with two controllers? Both controllers will be connected to the same battery leads (in parallel).
3. Will regular bearings be able to support the swingarm, or should I use needle bearings?
A rough schematic of the drivetrain layout:
Underside view:
Side view:
Top view:
The drivetrain is a fairly simple two-stage with a jackshaft in the middle, which sits on the swingarm axle. On the jackshaft I plan to have a torque limiter and disc brake, as well as the two sprockets.
I'm going to weld the frame out of mild steel because I don't know how to weld anything else. I wish I could make it out of aluminum, or pretty much anything besides mild steel, but that's out of the question unless someone on here would be willing to help me out with that! As it stands right now, the frame and swingarm weight almost 35lbs! I'm still in the design phase, so any comments or suggestions are more than welcome, you won't hurt my feelings!
Monster T forks
24†downhill rims
questions
Underside view:
Side view:
Top view:
