Long John Rider
100 µW
- Joined
- May 9, 2016
- Messages
- 9
I'm running a 500w gearless motor.
36V battery, which is healthy, no dramatic voltage drops under load.
This is my speed controller since about a year: http://s.aliexpress.com/yUBfiYbQ
I have a brake switch for regen braking, a toggle for cruise control, a toggle for limited speed, and a thumb throttle. No pedal sensor, and the hall sensor wires are not connected.
My wife rides the bike too, and reported what I believe to be the same problem as I have since this morning about a month ago, although it reportedly fixed itself and has been working since, until now:
When I flip the master switch (big dumb circuit breaker between battery and ESC) I get a few seconds of motor power before it stops, and it won't turn over until I cycle this breaker, when I get a few seconds again. I get no regen braking either when the motor is dead.
Is it simply a matter of replacing the ESC, or it there something else I should look into first in the rat's nest of wires and connectors? Is there a broken connection or short circuit that would produce what I'm seeing?
I could relatively easily try another thumb throttle which I have at hand (though I don't see why this should be the problem, it's just the only electric part that gets wet all the time I guess), less easily put my old non-regen ESC back in as a stopgap while I wait for a replacement regen-brake equipped ESC to arrive on a slow boat from China. I'd rather not go through all that hassle though, obviously, if this is something else that I can try. I just don't know where to begin to effectively troubleshoot this.
Any ideas or suggestions would be greatly appreciated.
