Dauntless
100 TW
fechter said:Tornados can help with tree removal.
nutspecial said:It's also the first time I've seen someone quoting their self, quoting their self, quoting their self. Everything has now lost meaning as if falling into a paradoxical moon bathed wormhole in the pantry.
nutspecial said:It's also the first time I've seen someone quoting their self, quoting their self, quoting themself. Everything has now lost meaning as if falling into a paradoxal moon bathed wormhole in the pantry.
dogman dan said:Cold and plastic can be interesting. I once climbed a very tall mountain, and got out a PVC plastic poncho, to make enough shelter to roll a joint to smoke on top. When I opened up the poncho, it shattered into pieces the size of a postage stamp and blew away.
DAND214 said:I sure hope you get this paradise done, before you have your stroke
Dan
amberwolf said:So it took you THREE THREADS for the same thing to decide to listen to what people were telling you?
Do you just like trolling by dragging out replies from people?
Debunker said:... so the big idea is settle the e-bike to gay-mode in the city (PAS and the lower power mode) and switch to full power for off-road fun.
Sunder said:flat tire said:In this case following the law is WRONG so following the law is not what is important. You have no ethical obligation to follow stupid laws
You know, tribal leaders in rural Pakistan said pretty much exactly the same thing, when laws prohibiting honour killings were imposed on them.
Good to see your maturity of thinking is at the same level.
AF7JA said:I read that article. I think the article is better summarized as "the technology, and infrastructure, for the elimination of fossil-fueled vehicles will be present within eight years." That makes for a far less sensationalistic article; but I suspect it will be more accurate.
It's a normal bicycle at the moment, which means that putting a front wheel drive on it makes it ALL WHEEL DRIVE. That is, assuming the rider isn't just a useless sack of fail.
Warren said:... wondering what the hell I was doing. Hey! I'm retired. I don't need to know what I'm doing.
liveforphysics said:Burning things most certainly has a known outcome.
Just use care when nailing cells together!latecurtis said:However even if I do order the LiPos I will still be building a large LIFEPO4 pack also as I KNOW I have the woodworking skills needed to accomplish it.
latecurtis said:Seems like you cut off the pedal chains on most every bike, then struggle to ever get one put back on.
You do know that you don't have to cut the chain to remove the rear wheel ... don't you?
No. I did not know that.
DAND214 said:Can't wait to not see what you're not doing
DAND214 said:
Kevinwilson said:Wow you guys are so hopeful best forum ever.
Toorbough ULL-Zeveigh said:doughnut 4get 2pull UP on your shoe laces to lighten the load. every little bit helps.
DanGT86 said:They can build it as an enclosed tamperproof system with good isolation whereas one of us would be risking certain death soldering an 80s lipo pack together on the kitchen table.
Dauntless said:swbluto said:And the greeks had this thing called the fates.
More to the point, they had Deus Ex Machina. But you don't. Get over it.
