safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
If you read my Project #001 thread all the way through (which is not an easy task) then you know that I went through several "transaxles" as I called them. My mistake was in underestimating the strength that is needed in the bearings. You need strength that is greater than a bicycle hub (I was using a steel rear hub and altering it) and probably less than a one piece bottom bracket set of bearings. I ended up with some high precision sealed bearings and it's gone a couple thousand miles without complaints.
So just be sure to go with the highest quality sealed bearings or you will find yourself rebuilding it again and again. And with an expectation of wanting to maximize torque that means that the stresses will be at their highest.
It's surprising how much strength is required even because of a tiny little motor... (they can surprise you with how strong they are)
The RC motors are even more extreme as they put out so much power for how small they are.
(the pictures are too dark for me to see what you are doing very well)
