same way you would on anything else. look at the links in that search and they show you how they work, so you could figure out how to add that to your design.qwerkus said:Great feedback - thanks! Not sure how I would implement a stabilisator on a trike.
. Besides price / complexity issues, the main argument is the loss of cargo space: the whole back gearbox + suspension in the fully design sucks up nearly a third of useful cargo space.
this is part of why the sb cruiser is the way it is, and why it uses big heavy hubmotors in the rear wheels vs a central drivetrain.
i have ideas in the works to use a differential to drive the (still unsuspended) wheels from a single central motor, but it is complex because the diff axle can't go to the hubs of the wheels, or else it will make a bump in the middle of the cargo deck, or actually have to be in the middle of teh cargo area.
so if i use a diff, it'll go under the deck, between the wheels, but the deck will be below the axle line, and the deck frame will "hang" from the axles, like it does on my big mk iv / v trailer, and the raine trike for my brother. so the diff will be down between the rims, really, just enough off the ground to clear the usual things, since stuff like speedbumps/etc will automatically clear as the wheels will force that.
then the ends of the diff axle will go to chain sprockets, and short lengths of chain will then drive the wheel hubs; both will use the largest practical sprockets to keep tooth loading down, whcih will reduce wear and increase grip/torque transfer.
the placement of the motor itself will depend on what motor i use, but a big hubmotor is the likely type, mounted in the frame in front of the cargo box under the seat, in place of the igh that's there now, simply becuase i already have a few to try. probably no freewheels, as those would wear quickly or break at the power level expected.
the pedal drivetrian presently goes to the left wheel, but will change to go to the front wheel (kinda like the cycletruck or whatever it is that ups is using some places), with an igh in the front wheel, or as a jackshaft (like it is now) on the way up to the wheel.
anyway, just ideas you may be able to use.
