fechter said:There are some existing magnetic gear setups.
https://www1.grc.nasa.gov/wp-content/uploads/2018EATS-Magnetic-Gear-Scheidler-6.2018-4988.pdf
If designed properly, the gears have nearly zero loss and zero wear. Most of the systems involve both attraction and repulsion and the gears will "slip" if the load gets too high, which creates a safety feature. No broken gear teeth.
Thx fetcher, I saw them.
It's great that too much torque just means slip, not destruction.
But
My think is why re invent the wheel:
A stock gearbox with repelling teeth would/should reduce friction and wear considerably!..?
The teeth could even be north on one side and south on the other (stock round magnet) as long as the box was put together so they repel.
