riwi77 said:Hi all!
I building and documenting based on Hiorth's DIY on instructables.com.
It will be modified for water cooling and the "motor pipe" will be threaded not glued.
You can see and follow the progress here
https://www.facebook.com/Wildtech-1442876945788613/
LogicalDIYBuilder said:riwi77 said:Hi all!
Awesome, I used the liquid force fish foil. I chatted with Hiorth's DIY on instructables.com and they are already on V3 much different and better, you may wanna hold off on copying their V1. Im sharing my build at http://www.diy-electric-hydrofoil.com/
slanton said:Why does no-one seem to use a water cooled outrunner motor?
Congratulations!!!superlefax said:Finally I did my first "surfing" on my brand new machine. I really had to struggle with water leakages in the propulsion system. My 3d printed parts weren't watertight at all. I had to spray them with clear coat and silicon. Everything is fully unscrewable which is a big advantage to find the leakages and to eliminate them.
Hiorth said:And Yes we are working on V2 that is improved. You can follow the progress here (for free) https://www.facebook.com/media/set/?set=a.10159438659855144&type=1&l=2e97c1f9fb
Cheers
Hiorth said:Thanksnope ordered from a supplier.
