Electric Longboard Building Using Carvon Dual Electric Hubs
Yes, you can still buy all the parts except for the switch/breaker which I recommend between 80A-100A for a Single Hub. You can also replace the FVT ESC with the VESC and it will be a much smoother ride. Check these threads:
https://endless-sphere.com/forums/viewtopic.php?f=35&t=73404&hilit=pediglide
https://endless-sphere.com/forums/viewtopic.php?f=35&t=74229&hilit=dervish
https://endless-sphere.com/forums/viewtopic.php?f=35&t=74411&hilit=jdogawesome
Evan, I recently made a build with the Carvon Single Hub V2 with slightly different parts. I use it mainly for daily commuting and wanted something stealthy and lightweight. The hub motor has really great coasting power and is super quiet with FOC enabled. Here's the parts I used if you'd like more info: http://runplayback.com/how-i-built-a-diy-eboard
