FawltyPlay
- Joined
- Nov 7, 2022
- Messages
- 3
Hi all, rookie here.
I've got 10 sticks of 12 NiMH cells welded together in series, each pulled from a 2005 Honda Accord Hybrid. These cells I believe to be rated at 6500mAh. The fully assembled pack should have 120 cells in series to give 144v nominally. The battery for this car is being troublesome, refusing to spit out as much hybrid assist as it should and causing some monitors to not set (according to the dealership, anyway).
Under normal operation I understand the computers in the car attempt to keep the SoC of the pack between 20% and 80%.
I am in the process of reconditioning the sticks individually and have reached a stage where I'm ready to rebuild the pack, if I can decide which cells are worth keeping and which should be removed.
From reading, it seems prudent that I balance the cells as best I can and discard any outliers. I haven't found great specificity in what an outlier is, so I thought I would check with the experts.
Using a Cadex C7400ER I was able to do two sticks at once, and gave each stick several cycles until the measured discharge capacity stopped increasing for 2 cycles in a row. Details for this can be found under "Prime" on page 25 (41 in the pdf) here: https://www.cadex.com/_files/243/c7x00_user_manual-rev11.pdf.
The results of this were as follows, for each stick as a percent of nominal 6500mAh discharge capacity:
Obviously some of those are alarmingly out of line with each other, but I seem to have brought them back in to being similar capacities. A suggested capacity deviation of 2% I found on these forums would mean a maximum difference of 130mAh. The largest between any two sticks is 260mAh (sticks 3/4 compared to sticks 8/9). Elsewhere I've seen tolerances of 5 or even 10 percent. Any alarms ringing?
One thing that was suggested to me was to allow them to self-discharge to see if they do so evenly when the car is not in use, especially given the high self-discharge present in the first 24h or so for NiMH cells. I am currently on day 4, with these results coming in (same stick order, of course):
Things seem *fairly* even here, but again, not totally sure what to look for. Stick 1 has aberrantly high primed voltage, while sticks 3, 4, and 9 have lower primed voltage. But after only 24h the cells are all within roughly 0.1v of each other. This feels like a good sign but I'm far from an expert.
Are there other tests I can run? This Cadex unit is pretty awesome and it doesn't take me long at all to charge or discharge these sticks so I'm game for most things.
As an aside, would it be useful for this forum if I documented the (dis)assembly process for this hybrid vehicle battery? The HAH in particular has scant information online.
- 91% -> 92% -> 92%
- 95% -> 93%
- 95% -> 94%
- 94% -> 94%
- 84% -> 92% -> 92%
- 21% -> 92% -> 92%
- 30% -> 94% -> 93%
- 12% -> 92% -> 91%
- 93% -> 91% -> 91%
- 21% -> 93% -> 92%
Code:
Prime Voltage | 24h (drop) | 48h (drop) | 72h (drop) | 96h (drop) | 144h (drop) | 168h (drop)
1. 17.90v | 16.28v (-1.62v)| 16.02v (-0.26v)| 15.85v (-0.17v)| 15.77v (-0.08v)| 15.63v (-0.07v)| 15.60v (-0.03v)
2. 17.72v | 16.29v (-1.43v)| 16.04v (-0.25v)| 15.86v (-0.18v)| 15.77v (-0.09v)| 15.63v (-0.07v)| 15.61v (-0.02v)
3. 17.36v | 16.27v (-1.09v)| 16.04v (-0.23v)| 15.85v (-0.19v)| 15.75v (-0.10v)| 15.56v (-0.09v)| 15.54v (-0.02v)
4. 17.38v | 16.20v (-1.18v)| 15.95v (-0.25v)| 15.77v (-0.18v)| 15.66v (-0.11v)| 15.48v (-0.08v)| 15.45v (-0.03v)
5. 17.49v | 16.24v (-1.25v)| 16.00v (-0.24v)| 15.82v (-0.18v)| 15.72v (-0.10v)| 15.59v (-0.06v)| 15.57v (-0.02v)
6. 17.70v | 16.18v (-1.52v)| 15.93v (-0.25v)| 15.77v (-0.16v)| 15.65v (-0.12v)| 15.51v (-0.06v)| 15.48v (-0.03v)
7. 17.73v | 16.18v (-1.55v)| 15.93v (-0.25v)| 15.76v (-0.17v)| 15.67v (-0.09v)| 15.55v (-0.05v)| 15.53v (-0.02v)
8. 17.74v | 16.26v (-1.22v)| 16.00v (-0.26v)| 15.82v (-0.18v)| 15.72v (-0.10v)| 15.58v (-0.06v)| 15.56v (-0.02v)
9. 17.30v | 16.17v (-1.13v)| 15.90v (-0.27v)| 15.73v (-0.17v)| 15.66v (-0.07v)| 15.54v (-0.06v)| 15.52v (-0.02v)
10. 17.44v | 16.23v (-1.21v)| 15.94v (-0.29v)| 15.77v (-0.17v)| 15.69v (-0.08v)| 15.57v (-0.06v)| 15.55v (-0.02v)
