999zip999 said:
Tony01 as smart as you are I thought you might want to share the pro's and con's of plugging into a 240v charging station. As I haven't mess with 240v at all. It sounds scary.
999zip999,
240/120 both should be respected, while travelling in south east asia, I have a few zaps of 240v, still alive but left a bit of a spot weld burn on my fingers
Being a newbie and not having read all the white papers, I enjoy these threads to learn [minus the drama]
J1772 plug + Pilot signal generator (AVC2.r) + 5-15R plug + Meanwell PS (auto selects 120/240v) + battery
1. J1772 plug by itself will the pilot signal generator to give you 240v at the plugs output wires
2. I opt for 5-15R plug so I can plug in meanwell
3. Meanwell PSs like RSP, HLG most of are compatible with a wide voltage range (88v to 280v or something), these will fine and I like them as they are well built machines, I lube the fan bushing/bearing with some TSI 321 yearly.
4. Battery - I am opting for pouch cell or prismatic cell batteries for my future builds. For example the Topband 25ah LFE cells can take a 25A charge. So with a 16s I can charge at 1.3 kw.
Ease of charging/access is the key here, most of us have batteries which can be charged at max 5A at 40v or 50v, so though we do not need a 7kw power source, it is good to have, if nothing, just to impress the ladies.
If you read Kingfish's epic Cali trip, he would charge anywhere he could find a plug.
OTS solutions:
I picked up a soldering iron after 18 years to build a XT-60 connector few years back for my lithium battery pack, so a off the shelf solution for guys/gals like me is preferred.
J1772 plugs is say $40, but you will need the comm unit, which I see on ebay is also $40.
For $85 we could probably find a reputable seller of J1772 plug with comm built in. I ordered one last week, once it is here I will test it and post it.
5. Using your existing 120v charger:
Back in the day, when I used to travel out to countries with 240v I used to carry a small 240v to 120v step down converter.
I used to see them in the walmart travel aisle many many years back, you can find one for few dollars online to use with your existing bike charger. I would get one with WATT rating that is 1.5x of your charger.
J1772 > 240v to 120v converter > Bike charger > Batt
[edited to incl, 240v to 120v converter option]
