G'day Hostile.
Maybe I can help.
I'm guessings your EVT 4000E is like these 2 I have lying around.
Under the seat, there's a storage tub.
Remove the tub and there's the battery compartment.
There's no battery box as such. The original 4 50Ah SLAs sit in there with tie down straps, like this in my 168.
I've added foam pads between each battery.
If you remove the storage tub you can fit in a 5th battery for 60V. Apparently the motor, controller & DC to DC converter can take it. There's a thread somewhere on ES about it.
The batteries plug in to the four Anderson plugs, seen here from the right hand side of the scooter.
I scrawled a wiring diagram for you, hope it makes sense.
And the charge socket
Pin 1 on the charge socket is positive, pin 5 negative.The original EVT charger is really 4x12 volt chargers and charged each battery separately. Batt 1 is pin 1 +, pin 2 -. Batt 2 is pin 2 +, pin 3 - and so on.
Keep us updated on how you get on mate.
AussieRider
