dragonfire
- Joined
- Apr 14, 2009
- Messages
- 112
As my SLA´s ae bloated i am going ahead with converting my Goped ESR750 EX from BB´s hr12-12 to Lifepo4.
In order to keep on using the stock onboard charger which is seemingly capable to charge LiFePo and even Lipo ( except balancing) in needed modes according the manufacturer i want to make packs that are cheaper than the oem ones ( 2200 dollars for a 32a upgrade kit...) but am wondering if i can use the 2,3ah´s per cell LiFePo´s instead their 1,1ah cells ( same voltage) and can save on the second pack of parralel cells the OEM version does have ( or should i get that a123 "26550"-Cells" ( Dewalt) setup for even more range ?).
this is the factory kit´s specifications:
14 cells (7s2p) at lbs of weight and 25,9v charged voltage ( allthough the onboard charger is reported to put out 24volts...? )
8ah per pack and 90 amps current draw capacity.
this in parralel gets 16ah capacity, a third pack added on 24 ahs and with 4 packs it shoudl be at 32ah, i figured i will want a 3s1p pack of those 26550 cells as a seperate booster pack to get voltage more closely to the 31 volts cutoff.
i am also not fully decided whether to use salvaged dewalt/26550 cells at 4.50€ "as is", or roughly 6€ per cell allready packed/ checked and with balancing wire from china ( includes custom and shipping fees, hence "roughly 6€") or ne cells at 12€ per NEW dewalt-cell respectively 7,50€ for the 1100 mah ones ( also new and allready with soldering tabs).
I am also yet undecided if going for a 16 ah or a 32 ah setup, as the 16ah setups seemingly allready get 10+ miles in range under heavy load this may allready uffit my purposes.
People have tried anything from 8s1p to 7s7p and got range increase, i mostly wonder if i should get the 1100 may cells or the beefier 2300 mah ones, even more considering the lesser the number of cells the fewer risk from not actively ruinning balancers on them.
oh´and should i install a safety switch on the cells that cut of to prevent overcharge and maybe also over-discharging if the controller is allready set to cut of at 20.4 volts per bank ?
