bigun
Hi,
I'm planning to do my first ebike build on a Motobecane Boris X9.
Have been reading a lot and I think I'm settled on the following:
BAFANG BBSHD 48V 1000W MID DRIVE KIT
1000W, 30A
100mm (Fat Bike)
43V LVC for 50V (14S Li, 16s LFP)
42T Bling Ring (Black)
left thumb throttle (TYP2)
2pc HWBS (Cable Type) Ebrakes
GearSensor (deraileur)
DPC14 color display
I'm getting stuck on the battery choice though. Here are the bundle choices/costs:
A few questions:
* I'm leaning toward the triangle 18,9Ah 14S9P-22P. It seems like the higher discharge cells would be a waste for a 9P BBSHD, which would draw 30A max. Are there other considerations? e.g, should i expect to get longer life (more cycles) from a 25R or 30Q variant?
* Question about the triangle packs. Since they are harder to remove, I'd assume most people leave them on the bike when commuting to work, or charging. Is there a good way to prevent theft of a battery in a triangle pack? Also, are these batteries harmed if left outside in > 100 deg F temperatures?
* For the charger, EM3EV has a 2A version for $30, and a 5A version for $60. If not concerned about fast charging, would the 2A version be better (I thought I read that charging slowly can extend battery life, is this true?). Can the 5A version be set to charge more slowly?
Thanks in advance for any input or ideas!
1000W, 30A
100mm (Fat Bike)
DPC14 color display
- 47V 9.8Ah (4P-25R) Frame Pack ($360)
47V 11.8Ah (4P-30Q) Frame Pack ($436)
50V 14.7Ah (14S6P-25R) Triangle+Bag ($531)
50V 17.7Ah (14S6P-30Q) Triangle+Bag ($631)
50V 18.9Ah (14S9P-22P) Triangle+Bag ($518)
50V 22.1Ah (14S9P-25R) Triangle+Bag ($751)
50V 26.7Ah (14S9P-30Q) Triangle+Bag ($893)
50V 12.3Ah (14S5P-25R) Rect Pack ($456)
50V 14.7Ah (14S5P-30Q) Rect Pack ($542)
50V 14.7Ah (14S7P-22P) Rect Pack ($423)
50V 20.7Ah (14S7P-30Q) Rect Pack ($694)
50V 16.8Ah (14S8P-22P) Rect Pack ($470)
50V 23.6Ah (14S8P-30Q) Rect Pack ($784)
A few questions:
